1.6 gti rebore piston search
(In Topic #203519)
Do any of you guys know of a source or alternative piston that is suitable? . cheers
I looked into sourcing some alternative pistons for a 1.8 and there was nothing even close. So many variants such as wrist pin dia pin C/L to crown height, compression ratios. You may struggle unless your lucky and a set come up on ebay.
Even looking into changing rods didn't help as big end dia, width c/l distances all pretty unique to vw's
I think the closest piston was an Alfa Romeo but it wasn't right and just as hard to get hold of.
There are websites out there with lots of sizes for comparison but they take some finding.
My 1700 EG used stock Corrado G60 pistons (81mm) but the block was decked to suit.
Last edit: by addicted
barney6 said
Oh boy is it the same for 1.8 engine as well ?I have a 1.8 engine that I thought ,If I could not source pistons for the 1.6 I would rebuild that. Back to the drawing board.
barney6
I don't think its an issue for 1.8's - not yet anyway. I was carrying out research for a different exercise altogether.
I was trying to see if it was possible to make a 2.0l from a 1.8 short block cheaply by boring out and using a different crank or off set grinding it. Nothing VW made was going to work so I started looking at alternatives but there was nothing obvious that used VW's dimensions.
Didn't they make an 8v version of the bubble block? or where they all 16v?Yomp said
Edit: I just checked, the 3a is a short block 2.0 8v..
addicted said
In one of my modded EG's I ran pistons from an early 10v Audi Quattro Turbo (Audi used the EG piston as a base for the early quattro turbo), I know I had to modify something to make them work, but it was nearly 15 years ago so cannot remember what.
Thanks I will look into that
I was trying to see if I could hide 2L internals in a standard 1.8 block with maybe just a rebore. Its been done as tsr sold them but not sure what crank they use? Maybe a AAZ diesel?
barney6 said
Looked into the G 60 option, PG engine code pistons still available in Germany but £140 odds each !! so bit the bullet and gone down the Wossner forged piston route just means she might not be on the road this year again. Still she has not been on the road since 96 so another year will do no harm thanks for the replies.
You can't go wrong with Wossner although probably over kill on a standard engine. Look on the bright side you maybe able to shove a load of laughing gas in as and when the need arises!
