1.6 EG oversized cast pistons/ GE trans gear ratios-
(In Topic #216326)
Looking for info
I'm in the process of restoring my 78 series 1 GTi.
Does anyone have a set of good/ used or NOS oversized cast pistons for the 1.6 EG??
Also, what are the gear ratios for the original GE code 4-speed trans?? I've looked at several gear ratio charts and searched with no luck…
Any help is greatly appreciated!!
Thanks,
Chris
https://www.ebay.co.uk/itm/112785891572?ViewItem=&item=112785891572
or search on german ebay
4 x Kolben vollständig (übergröße) ø 80 mm Vw Golf 1 GTI 1.6 EG Jetta Scirocco
1st is the same as all 020 boxes I imagine. Maybe you could look in the parts book and that list the number of teeth and work it out from there?
Thanks so much for the info guys!!! That is an excellent lead for pistons!!!!
As for the gearbox, I have been researching.. for now, I have figured out that the GE box has a 3.70 final drive, and the GC is 3.89 ( I believe )
I will post more as soon as I learn. It may come down to counting teeth, so I will do that if need be. My gearbox is now broken apart..
If anyone else has any info, it would be greatly appreciated!!-
GE 4-speed final drive / ratios-
Final drive - teeth- 74:20 = 3.70 *specific to GE code*
1st gear - 38:11 = 3.54
2nd gear - 35:18 = 1.94
3rd gear - 36:28 = 1.29
4th gear - 31:32 = .969 *specific to GE code*
The eBay seller mentioned above is out of stock on the O/S pistons. If anyone else has a lead, please let me know-
Chris
Chris
Thats hard luck on the pistons because he's sold a few sets over the last months. It was the only lead we found.
