problem with temp gauge and flashing lights
(In Topic #99361)
Providing your coolant is topped up and the fan cuts in when hot and the car does not overheat , don't worry i looked in to this problem along with other users and found despite replacing temp senders , coolant senders etc that the clocks were to blame . Replacement is the cure . Great except you can't get them 8O New only used items .
But thats not the end of it ! You must make sure before you blame the clocks all the above + you are using the correct anti freeze mixture and that the water level is on the Max mark . And you have checked all coolant senders and level indicators by replacing them .
Cheers ………..
i see
i will start replacing the temp senders and see how i go . . ive got no anti freeze in as it never gets that cold down ere . . but i will put some in just for fun and see how i go ..
thanks for the reply
Re: i see
trevorhutchins said
ive replaced the clocks with mk2 gti items and still have the same fault
hi there! i also have mk2 ce2 dials installed in my mk1. i have the same problem and still im trying to figure out the annoying coolant level light flashing after a year of research. did you fix yours? what did you do? i had all the wires checked, relays and sensor. used the same cluster with a different auto and it worked fine. thanks! - jtec
I have done a few MK2 in to MK1 clocks now and never had this issue ? Oil buzzer and light yes .
Make sure you have no xtra relays as per this The Mk1 Golf Owners Club
Also see http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=35823
Post back !
My conversion uses a 20VT sender from the 1.8T engine :dontknow: Perhaps the later MK2 had a different sender ? My temp guage reads slight high at normal running but the bulb has never flashed
Worth a look at , senders are cheap .
You could also remove the coolant bulb ! It wont flash then .
