Pedal mounted brake light switch
Is the wiring the same for this conversion? i.e the connectors etc
The switch mounts on the pedal box - i beleive the later cabriolet had this arrangment rather than the in line pressure activated switches…
cheers for any help as I am about to commence running in the lines.
I put a post up about this on edition 38 and mr brown advised that you need the wiring going back to the fuse box from the car that you get the steering column switch from. Im sure the original wiring could be routed back in to the car and modified, after all it is a simple on off switch just maybe not as neat.
Helios Blue
