fuel gauge
(In Topic #72257)
fuel gauge
not good not knowing how much fuel is in the car!
It might be that if you connect the two wires that go on the sender (through round plate under rear seat) the gauge will read full - can anyone verify that? This will confirm wiring and gauge is OK or not.
r they linked??
gotta sort all these little, but big headache problems if im gonna sell this when i get mine back!
They sure are linked, do you have haynes manual, they tend to have the best wiring diagrams?
If I remember rightly they share an earth.
Peter
1980 1600 GTI, daily driver.
Life Member
http://www.campaignreg…orum/viewtopic.php?t=1369
but lasted about 30 seconds…..i take it this means the earth tallpete is talking about is the route of the problem?? where is this?
need a new voltage stabaliser now :evil:
good thing is that i connected the speedo cable to the clocks and it works! - other end was disconnected too… also the mpg air hose was diconected too so thats also now working!
should be sorted this weekened! this car is all comming together now! only other prob is the heaters! see my heater post!
Life Member
Would be worth cleaning up the rosette anyway and see if that sorts it.
Sometimes it's worth running a separate earth to the instrument cluster particlarly if the dash is out (Come on Wellsy give is a definitive how the MFA works - you know you want to )
Wellsy
1983 MK1 Golf GTI (Campaign?)
1983 MK1 Golf GTI (Gone to VW Heaven)
1990 MK2 Golf GTI G60 Edition One
Life Member
but found there was another earth sum1 bridged from the brown earth from pin 2 going off sumwhere?? - could be immobiliser, also found that if i turn ignition on b4 putting immobiliser key in it works!!! soon as i put the immob key in and start the car the gauge turns off………
grrrrrrrr!!!! :evil:
well at least i can check how much petrol i have b4 i set off…
im thinking. new diode and get rid of that earth thats been bridged should do it..
Life Member
