Indicator light on the dash staying on?
(In Topic #114791)
Life Member
Try fuse 19 - it may be blown.
Also check that the single spade connector on the back of the hazard switch (blue/black wire) hasn't become disconnected causing the same fault.
It's the actual flashing signal from the relay back up to the switch and if it becomes disconnected then you just get +12V to the indicator whilst indicating resulting in a static green lamp on the dashboard.
