Suspension replacement what other bits do I need?
(In Topic #218800)
Anything else have speing compressor. Any tips as to not throw alignment out?
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F381430342628
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F151097102012
Don't get this kit as the springs shocks etc comes with bump stops and boots.Roach said
And these for the front.
Just buy the mounts and bush.
https://www.ebay.co.uk/itm/VW-GOLF-Mk1-1-8-Top-Strut-Mounting-Front-82-to-83-Repair-Kit-171412329AMH-Febi/332451130267?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D53675%26meid%3Dcb5263bf5f4c470c9baf6ce2e4d83ac7%26pid%3D100005%26rk%3D2%26rkt%3D5%26sd%3D332451129931%26itm%3D332451130267&_trksid=p2047675.c100005.m1851
you will also need a Allen key and a ring spanner or open sided socket to undo the front mount.
not sure what size you have so double check before buying but I use something like this.
https://www.ebay.co.uk/itm/Trident-T321121-Diesel-Injector-Socket-21mm-New/161859835203?epid=19017010154&hash=item25af991543:g:QRgAAOSwAYtWIMdB
I would also not worry to much about upsetting the camber and tracking as it’s best to get it set up again once it’s all back together as the tracking will go out as it will sit lower than the original set up and no matter how much you mark the camber bolts they will go out as there is some free play before they adjust the camber, worth paying the money to get it set up right unless you have a camber gauge.
Last edit: by mark1gls
Current rides:
