MK 1 GTI down on power
(In Topic #187374)
Sorry I don't post much but do trawl the site often, I had my mk 1 put on a rolling road last weekend as it seemed , well not a GTI power wise. ANyway it started off at 84hp, after a bit of adjustment and several runs they guys managed 95.2 hp with 108lb/ft torrque. now i know this is quite a bit down on original figures, the car has done 169000 miles. it is also run on normal unleaded, the guy suggested I run it on v power. has anyone got any pointers so I may get somewhere near the original figures or is it a total engine rebuild ? thanks for your replies in advance.
Daz
mk1 gti mars red /deep blue pearl r32
If its otherwise running OK (no smoke, no rattles, no knocking and good mpg) don't think I'd bother with a full engine rebuild for a few extra hp? Presumably that's what the R32 is for, going fast?
1. Is that power figure at the wheels or the flywheel - think the 115bhp (or whatever standard is) is flywheel which would equate to about 95 at the wheels I think.
2. Rolling roads won't give an exact reading - they are interesting to compare cars with difference mods / engines and serve a purpose if you are comparing yours over time (for example getting a baseline reading and then adding performance parts and seeing the impact).
Things like wheels and tyre pressure (rolling radius) along with when the road was last calibrated all make a difference too.
The above certainly used to be the case 10 / 15 years ago when I was into such things.
Y plate Mk1 GTI
65 plate 430d - newest addition
52 plate VW Bora - daily hack [255k]
15 plate 330d Touring - wife's car
the figures were at the wheels, Like you said you will lose a bit through the tansmission,, it has the original wheels with new tyresSvenM said
Probably a couple of obvious points but I'll make them anyway:
