High Clutch issue
(In Topic #215338)
Any help or opinions appreciated, I have bought a new clutch but am reluctant to fit it if there could be another issue or non at all and I am happy to leave it on the shelf in my container never to be used.
Alex
High Clutch issue
How was the clutch operation before the new cable?
Did it behave as it does now?
Do you happen to know what sort of mileage the clutch has done?
The reason I ask is because a few years ago I needed a new clutch cable while mine was at VW for something else and the plonkers fitted the wrong cable which was to short and with no adjustment and I had the same symptoms as yours!
I'm not saying don't replace it but I think it's worth spending a few minutes thinking about other possibilities.
I'm sure your garage workshop is telling you the truth, the whole truth and nothing but the truth.
As with my VW service manager when he tried to convince me that they had fitted the right one.
Once I'd purchased the right one you could see there's was a full 8 inches shorter!
Sent from my Smartphone 📱
You should have about 10mm of free play at the top of the pedal? (pedal moves easily before starting to feel as if any thing is happening)
Normal for the biting point to be some where near the top so I would not worry about it just yet as it's not slipping etc…
Don't go into 1st gear when moving, you should stop and then engage 1st as it's not good for the gear box, 2nd gear will pull the car from a near stand still.
The box just isn't designed to be doing that. 👍🏼
I have driven the car a little more today and yes it will not go into gear when moving, only as I come to a stop which is good.
I have the new clutch on order as a just in case. I don't know how easy it would be to get one quick to Mallorca.
From memory it was ever so slightly higher on the bight before the cable was swapped,
The performance is very similar not too hard to depress, we swapped it out as a cheaper and quicker way to see if we could make lower.
Interesting to hear about your issue, with the length. I had a quick look yesterday in the rain and noticed the plastic nut, just need to get back to work where I can get my tools and have a look at it a little bit more.
