Gush of air when opening fuel cap
(In Topic #210005)
I'm mean I'm guessing you had to refuel for a reason.
My two golf's, the Mk1 and Mk6 do that all the time no matter have much fuel is in the tank.
As far as I'm concerned that tells me I've got a good strong seal on the cap. 👍
But maybe someone knows better! 🤔😉
Sent from my Smartphone 📱
"There are two cap types, vented and non vented, GTIs must have a non vented one fitted.
You will find "Ohne blau Lüftung" stamped on the metal part."
so that would suggest carb engines should have a vented cap on it, if yours is not that could be why
All my mk1's have done it.
possibly the tank vents are blocked/kinked somewhere? you have some pipes up to the gravity valve in the wheel well and a long thin pipe that pokes out behind the tank somewhere
On the drive
Myvalver 89 GTi Grey mk2 16v
84.5 Cabbies and up, have an in-tank pump.
If the In-tank interconnected is weak, or holed then 45 psi can fill the tank.
If the fuel regulator (DIGI) is Wonky, or your running down the road, Fuel is returned to the Tank under Pressure.
If you have a good working system then up to 29 psi can stay in your tank with a vented or non vented cap, and it depends on what the cap is rated for.
On a hot day Fuel will expand as in GAS…..
On cold DAYs it will contract
So what I have noticed is that on Cold days it vents less
than on hot running down the road days.
The Emission Nazis over here Tests the CAPS for holding pressure as a VENTING cap screws the environment adding to GLOBAL CLIMATE CHANGE, Increasing the CARBON FOOTPRINT Melting the POLES,
"Funny I haven't seen any photos of Polish people Melting or getting smaller" causing the Polar Bears and Muskox to look for towns with large Freezers……
So I would Say, NORMAL, as I know it.
Life Member
I for one am not bothered in the slightest!
Your cap is unvented - that's what the German means.
in the UK market we didnt get that till the mk3 golf
