Front wheel bearings
(In Topic #220748)
Ashton09 said
I know sounds daft but you do have your C.V joint in hud as it's what holds bearing tight when you tighten up the nut
I actually haven't got the cv joints in no, surely even with them out it shouldn't have lots of play in it?
Same as if you tow them with no shafts in
The bearing fall to bits
I would do nothing till you put shafts in and tighten up the nut and recheck
Don't worry that's totally normal don't worry
Bearings shouldn't have play in them when they are new but until its all bolted together its impossible to tell if they are good or not.
Just make sure you follow the correct procedure when tighten the driveshaft nut for the first time (most people dont!)
Lets say for arguments sake the driveshaft nut torque settings is 200nm.
Tighten it initially to 120nm then undo by 180 degrees. Rotate the wheel at least 90 degrees and then tighten fully to 200nm
This helps seat the bearing fully in the hub, dont just go straight in with full torque and assume it'll be ok
Current rides:
WATERNAIR said
No but had it twice on my VRS.
Cheers appreciate the help, I think it might pay to bolt the driveshafts in and see what it's like first before worrying too much and pulling them back out for another set.
Briano1234 said
On mine when the hubs re fully seated with the ptoper pre-load, Taking for granted that new hugs are used I never have any free play.
Got to give your bearings hugs, make them feel loved
JakeMcC said
In terms of brands, I always try to use SKF or FAG bearings regardless of the car - SKF are an OEM bearing manufacturer for VW.
They're FAG bearings these ones I've fitted, the company did say they were the better option to be fair its just I presumed they wouldn't have any play in them. I'm going to get the driveshafts bolted into place and make sure there's no play once torqued up as its going to be left for a while as I get on with the bodywork again.
I have heard of folks that remove the grease seals on the new bearings so they can pack more grease in them prior to installing.
As 1985 said, it's impossible to tell until everything is torqued - they could be totally fine Either that or return them and get a replacement set, FAG are certainly a well reputed brand.
Regional Host NE
in the outer casing until fitted
and tightened
