30 years of electrical bodge
(In Topic #222223)
Hi Guys whilst looking at the heater switch i decided to take a look behind the switch, i took the radio out to have a better look at seen this. yet more wiring to sort out.
if you have an idea on how to tackle this please hola, as i really dont fancy trolling through countless wiring diagrams.
if you have a layout of my fuse box that would be super as i dont know what fuses are what at present.
Mk1s had minimal radio wiring from factory so the chocolate block wiring to the modern ISO plugs looks ok, the only alternative is to solder and heat shrink.
The black/whites are the speakers, I'd follow the power (constant and switched) and earth/s and solder new conections or run new wires to pickup from the fuse box.
Theres a recent thread about radio wiring that has input from rubjonny that has the fuse box locations.
So having identifies the radio loom of sorts , the wiring to the right is extremely dodgy, have a look at the pictures can you identify any of the wires that arent connected to anything, the yellow circle highlights the cables for the rear screen heater 'these dont look original, do they look correct?
No that isn't correct, but the original Defroster connector can get toasted or burned 4 pins, 2 for the switch and 2 for a lamp that were tiny.
Crimps will work.
Crimps will work.
Thanks Brian i will have to try and find a wiring diagram for this is there a test you can do ? to identify if the rear demister is working. resistance across the terminals maybe
Yes you can do a test between the left and right side of the demister grid, there is also a test of the individual grid strikes as outlined in the Bentley or haynes.
I have repaired the Demister grids that has broken runs with conductive Copper Paint….. and Conductive paint pens.
Thanks pal , whilst doing the heater i found the spade earths, so may re run some decent gauge cable, i could see the old cable albeit toasted so figure theyve replaced at a later date
whilst looking in the radio area i Noticed around 5 wires that had black tape around them, typical where will this stop any ideas chaps
those are the original speaker wires. if you find the speakers you'll find the other ends to help you ID which is which
for the main dash harness have a look in my signature link 'jetta89.pdf' its close enough for your needs, also check my fusebox FAQ:
https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/
Thats a massive help pal dont suppose you have a diagram for all the dash switches?
psst, it is in the Bentley or the haynes for your model and year specific.
dash switches are covered in the jetta89.pdf, mk1 and mk2 use the same switch pin numbers
the headlight switch is a bit different to what you have but enough of it is covered to get you through. If you haven't got a brown haynes yet though be sure to get one, its very good. Make sure its the later revision which mentions cabrio and scirocco on the cover.
a bentley is almost as good, what it does cover is as good as the haynes its just its not quite as good for euro models. for example non of the 1.0-1.6 engiens are covered, and nothing in there on the carbs. The wiring diagrams are great, but again euro specific stuff will be missing. The dash wiring sections are all good though
I will affirm, and say that for 20 years all I had was a Haynes to keep my 81 Westy rabbit running.
A few years later after owning a 89-90ish- Cabriolet the
Bentley had a better layout, but as I see from this forum it was a little lacking on the Euro Versions of things that we in the US had.
I will also state that the Haynes that I have for the 80-90 Gassers has better quality electrical pages than the Bentley.
Both are lacking in some areas, as in body, and how some a/c systems work, as well as you have to shuffle between regular Cabriolet or Diesel schematics to the specfic ones for power windows, heating when you have a/c, and such.
What I really enjoyed seeing was a 1980 and earlier Gasser version of the Bentley, that had Colored Wiring pages…. Picked it up for 1 buck at a Yard sale.
Thanks Guys so its the brown haynes for my 89 gold cabriolet ? just seen theres several brown Hmmm
More likely to find a Haynes over here, since Bentley is an American thing. That's the best version of the Haynes yep
In a nutshell usually if you have a us car, buy a Bentley and if European Haynes. There is a lot of overlap between them but the Bentley covers us specifics better and Haynes euro specifics better.
I have both, and for most things either is brilliant. But if you want help with a 2e2 carb the Haynes is the manual to have and if you have an American Aircon system to fix then it's the Bentley you really need :p
