Suspension advice if poss
Coilovers or uprated shocks
Hi all
I am after some advice if poss, I have  mk1 convertible that I purchased last summer it came with a set of H&R coilovers on it. It does sit very low and is a very hard ride. There doesn't seem to be enough adjustment to raise it to the height I would like 30-40mm from standard, I was thinking about getting some longer springs to change the ride height. I am now wondering if I would be better getting a new lowered kit (not coilovers) so would not be quite so bumpy poss spax or another not too expensive.
thanks guys
Not a coilover expert but would have thought adjustment would go to standard height. What size wheels and rubber do you have on? Could it be small and skinny? My cars ( lots) running 195 50r15 on 15 bbs rm,ra,ronal turbo some are on standard some on coilovers find anything lower 21" (floor to centre of arch) breaks my spine 195 55 rr15 made a noticable improvement on turbos,even stopped cd skipping
On the drive
Myvalver 89 GTi Grey mk2 16v
H&R coilies are supposed to be quite good.
Do they adjusters on them for stiffness within the shocks at all? A little knob either at the bottom of the shock or on the top where they stick through the body.
Any pics or product numbers?
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
thanks guys for the replies, I don't think they will go anywhere near standard ride height I think min is 50mm,  it has got the standard 15 inch rivage wheels and occasionally catches on speed bumps (they are quite bad near me). Also we use it daily school runs ect and there is not much give in it. There is no top adjustments unfortunately
If you want non-coilovers, Eibach Pro Kit are very popular and about the height you are looking for. You could partner with:
Bilstien B4 - reasonably priced and well respected.
Koni Sport - a bit more expensive, but adjustable damping (what I am going for).
Bilstien B8 - A little more. Some find them a little stiff, but they are meant to be very good.
There are plenty of other options, but those come up a lot.
Whip
/wip/
Noun - Car
thanks all think might give the Bilsteins a go
You can find them as a kit if you go for the springs as well.
Whip
/wip/
Noun - Car
must admit have been looking as a kit but can't seem to find
https://www.ebay.co.uk/itm/233057941786
The fronts in the pics are insert dampers, but the pic are often wrong though. Can always call to check.
Whip
/wip/
Noun - Car
thanks for that I did speak to them they don't have the front struts in uk but can get them in a week so think may go with them thanks, whole kit £400 not bad.
Thanks for your help will give me something to do with all that going on :)
Hi rubbs, are you parting with the coil overs ?
Cheers Gaz
I will be selling it at some point but tbh not sure what its worth so was thinking would prob just list on eBay
Ok cheers , thanks for the reply. I'm looking for a set of coil overs for mine so if you do get a price in mind and its within what I want to spend I'll have them off u? Or if u still want to put them on eBay could u send me the link to it when u list them please. 07703755404 cheers Gaz
I also have a full setup of standard suspension that's not been on long if your looking for stock height.
We could do a deal?
Cheers Gaz
Hi Gaz
I will give you a shout, I have just got the new Bilsteins and springs. Prob will wait till out and about before doing anything but will drop you a text
Ok thanks mate
Hi Gaz
If you are interested I have just listed the coilovers on ebay
item number 133401624965
or the link below may work
Rob
https://www.ebay.co.uk/itm/Vw-Golf-Gti-Mk1-Convertible-H-R-Coilovers/133401624965?hash=item1f0f5b4185:g:UeoAAOSwNZNerzpA
Hi Rubbs
Thanks for that I'll keep and eye on them
