Need inner daylights/fog lights for 1991 Cabriolet
(In Topic #232376)
Fog Lights
One of my inner fog lights got cracked by a stone and trying to find a new pair of one for my 1991 Golf Cabriolet
Seem to be difficult to come by…
Found these, would they fit?
https://www.ebay.co.uk/itm/PAIR-OF-VW-GOLF-MK1-1974-1983-INNER-HALOGEN-GRILLE-SPOT-LIGHTS-SPOT-LAMPS/323972582207?
Regards
Rachel
1991 VW Golf Clipper Cabriolet
"You only have one life so make the most of everyday"
headlights on full beam, blue light on dash and they should light up?
Yes, they are my high beam light, have been trying to tell people that but they keep saying fog lights lol.
Any suggestions on where I can find replacements, tried using the code on the Hella lights but nothing
https://www.ebay.co.uk/itm/VW-Golf-MK1-Hella-Grill-Headlight-301-131040/164748026396?hash=item265bbf621c:g:f1gAAOSw9L1fxS~-
https://www.ebay.co.uk/itm/VW-GOLF-MK1-HELLA-FRONT-TWIN-GRILL-GRILLE-HEADLIGHT-303131040/153395538429?hash=item23b71629fd:g:mCoAAOSwCnVbwIXE
https://www.ebay.co.uk/itm/Original-VW-GOLF-MK1-HELLA-FRONT-TWIN-GRILL-GRILLE-HEADLIGHT-303131040/352844900292?hash=item522731e7c4:g:mcIAAOSwJcNdwiti
Can't remember if they are "sided" or not
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
These?.
Yes they are sided that is the left is different from the right mounts.
So we are saying as they are sided I need to make sure I find one for the passenger side as that's the one that is cracked? (Briano)
here is what they look like from the rear.
https://www.heritagepartscentre.com/uk/volkswagen.html?cat=1005&type_of_part=357
For if you can find a local hella distributor give them a call and they might be able to get you some.
Unfortunately Mark, I need one in the next 4 weeks or less as moving back home to Austria and taking my baby with me (driving her over). I've got new LHD headlights so that's all sorted just this little problem which came out of the blue….
There is a large automotive distributor which sells old classic car parts so friend popping in there to ask if they have maybe one…
Whip
/wip/
Noun - Car
/wip/
Noun - Car
the_whip said
Those lights are pretty easy to "de-haze" as, unlike the headlights, they don't have the centre reflector blocking the entrance. You can just wrap a bit of cloth around a stick and clean it that way.
Hot water about 140 degrees, and 2 Denture tablets crushed let sit about an hour, then rinse with hot water and drain. After you get most of the water out, you can use a hair dryer to heat the glass and evaporate the rest.
Good point, I forgot about that… make sure you get rid of any moisture so you don't seal it in.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
