Lowering,Tyre choice,deeper dish
(In Topic #233966)
Hello all
Just need a bit of advice
My car is lowered on bilstein eibach springs
I've got some bbs rs et 25
with 7 lips front 7.5 rear
What is my best tyre options
And could I go wider on the rears with no fouling
Thank you
Thank you
1983 black gti ELD380Y
I had 15x7 et 25 all round with 195 45 R15 tyres on mine with the same suspension set up, I had the tyres rubbing on the arches at all speeds when going over bumpy bits of road, but I would assume it would be ok if you were to roll the arches. I had the same wheels and tyres on with coilovers and it sat a touch lower but it didn't rub on the arches with those tyres.
Would I be better of with narrower tyres
Or is it the offset that's wrong
Yeah, normal et is 38 so you are already 13mm sticking out without the extra width. I used to run et 35 7 x 15 with 195-50 tyres on 25 mm lowered springs. No rubbing anywhere (never 4 up) with plenty of clearance on the rear..
Mine is lowered by 35/40 front 30/35 rear
Would the best option be run 185 45
Perhaps machining could be an option
I couldn't say weather a 185 45 would be ok as I've not tried them but I'd say it would help, if it were me I'd look at changing the offset though, or roll / cut the arches
