High Speed stability ?
(In Topic #222052)
Lets make a thread with all the knowledge regarding wheel geometry
My main problem is, I want more high speed stability in my mk1. 200+ km/h. And I would like to hear if anyone have succesfully changed Caster angle and felt this help with the stability ?
Other things that would help with stability ?
I have changed alot on my car so it is for sure not original.
I have the JOM blueline suspension and Urethane bushings in front. To get better suspension and the car low enough I made two top mounts that raised the top bearings 2", this gave me more suspension travel, but also locked the top mounts in their position, since the spring now goes inside a tube that barely fits. Is I want to move the top mount further back, I need a shorter damper, otherwise I would be on the bumpstop.
I also made balljoint extenders to get better angle on the lower arm, and im now thinking if I could move the balljoint a bit forward to increase the caster angle, and then give me more stability.
Maybe I should mention that I have no sway-bars on the car. I'm also thinking on getting on from a scrapyard to mount on the rear axel, i read that this should be the way to go. What do you guys think ?
Maybe peoble with good handling low mk1's would like to share their suspension setups?
thanks
I'd say without ARBs (GTIs came with front and rear as standard) you'll suffer. Also, different castor from side-to-side (it is measurable, but not directly adjustable, but its related to camber) is going to lead to instability.
A nicety is also to balance out the corner weights - being a LHD car really helps here, because the engine is on the right.
Beyond a certain speed its more aerodynamics than suspension tweaks which will help - assuming its properly set up suspension without missing or worn components.
ARB's is for sure something I need, I read that many don't seem to feel difference with the front one, and with my already nose heavy car I planned on skipping that and add one on the rear (also read that that really helped alot of guys)
What is your 2cent about ARB's ?
thanks for the idea of balancing out corners (simple and usefull)
Aerodynamics is def. something I thought about, I have the GTI front spoiler, but is their anything else that is prove to help with stability ? Or is the rear spoilers just for looks ?
ETA regarding the R32 swap, what I would do is compare the front axle weight of a standard car with your car; then whatever percentage greater yours is, adjust the spring rate, damping rate and stiffness of the ARB by that amount, to ensure its balanced. If you used coilovers to do the lowering then you can buy ones with adjustable damping, and you can disassemble them to remove and replace springs - outlets such as Demon Tweeks sell custom rate springs.
Did you relocate the battery or keep it in the engine bay? It might help a bit to relocate it, some VWs which used the 6 cylinder engine had it behind/under the front seats.
Last edit: by paul_c
I would love to know the axle pressure on a standard GTI golf mk1 to compare ?? Any one ? I believe the 4dr is a bit heavier, so that would also be good to see.
the battery is in the trunk for weight also washer fluid container
about the adjustment of suspension, I will try to swap the JOM blueline springs with some springs from another set of coilovers from a passat vr6, I believe they would have a higher spring rate, but I dont know the excact amount.
