Cleaning tail gate decal
(In Topic #212679)
I have been given all sorts of advice over the years but now want to do something a bit more correct. And for those wondering the advice has included
Tyre shine
Baby oil
Wd40
Dashboard silicon
Pledge
Autoglym do a good silicon based satin shine from memory a green smelly one.
http://www.poorboysworld.co.uk/cgi-bin/pbw.cgi?Command=ShowEPage&db_epid=35
Use it according to the instructions and it simply does the business. 😉👍🏼
wilko13 said
It's a shoe polish I use it on my cabby for door handles B piller and rear number plate holder
I only use the Kiwi Quick shine on my Air bag… Gets it to match the leather.
But I found better for the other plastic bits.
After removing the handles off the door I found that cleaning the plastic handles, really really good Hot soapy water, then using a metal polish or Clear coat Polish makes the handles look new, and stay that way for a year or two. Using a Variable Speed Dremel on low with the Polishing wheel makes the job easier.
I found that by using wet/dry sandy paper on my "B" pillars then followed by again clear coat polish they shine big time and I think it's been 2 or 3 years since I have done it as well.
Before 1000/1500/2000/3000 wet…. doesn't take much, same thing I use on my vans headlights to decrapazoid them
sanding
After the 3000
Prior to the polish
You can use your fingers or a drill with a polish pad (works good in the handles)…..
Now for the rear license surround, I cheat a bit.
Remove from the car. Clean it with hot soapy water and a soft brush. Let Dry.
Use painting alcohol and wipe the plastic a couple of times…. Allow to dry.
Spray with Krylon Fusion Satin Finish Black paint, 2 coats…. it is usually good for 5-8 years…..
For the time to keep it clean, I would strip it off, clean the paint mask and spray it either flat black or Satin..
The 2 coats of clear satin….. easier to maintain…
Last edit: by Briano1234
