Red flashing light in temp gauge
(In Topic #154033)
Steve
My two things I'd replace first are thermo switch on radiator (this controls when the fan should kick in)
Then it would be thermostat under water pump, could be stuck open/shut.
Turn the car in and open the expansion cap should see water trickling in if the pump is working.
Just my input fella
Steve
http://www.ebay.co.uk/itm/Expansion-Tank-Water-Coolant-Level-Sensor-VW-Golf-MK1-MK2-T25-Passat-D-Jetronic-/310603066870?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item485162adf6
the temp sensor is the black single pin jobber in the front or side flange on head, sometimes all they need is a good buff up and maybe a new spade fitting if its hanging off by a few strands of copper
steve
it steve
