Vr5. 170 into my mk1 rag top? How?
(In Topic #216458)
Sent from my ALE-L21 using Tapatalk
you dont need the MK4 clocks, can defeat immo and convert it all to run the mk1 clocks. but if you did fit the mk4 cluster then immobiliser would work, rev counter etc.
Wiring wise try here:
http://clubgti.com/showthread.php?267196
for the v5 rev counter if its earlier type with coilpack this might work:
http://clubgti.com/showthread.php?98913
otherwise one of these will convert the ecu 5 cylinder signal to mk1 clocks:
http://ashlocktech.com/Home.php
a 20v type tacho converter wont do the trick as there are too many cylinders, you need a 5->4 cylinder converter then low -> high amp signal converter
if its a 6 speed box you need custom shafts plus if you want mk1 clocks you need an electronic -> mech converter for speedometer as they only have a hall pickup type. 5 speed box is driven off a gear inside the box so you can use 1.3 speedometer cable same as you do with the 20v swaps.
Birmingham
