Timing on a DX in a campervan
(In Topic #215850)
It had this engine when I purchased the van 9 years ago and I think was transplanted back in the early 90's from a mk1 golf.
I will be changing the cam belt in the next few days and wanted to check the timing is all correct.
I just wanted to check the process as I have the strange situation where I don't think the flywheel marks are the same as a standard mk1, maybe due to the T25 gearbox it's fitted to?
I do have a timing light that I can set the advance on however with fuel costs and fact its in a van I will not be using super unleaded 97 octane.
Can anyone tell me if I can do this without having a TDC or 6degrees before TDC mark on my flywheel to go by? Should I aim for TDC given the fuel I will be using?
And if anyone has a rough guide that I could follow in my situation that would be amazing. I am basically unsure which markings to use the timing light on. Thanks
Last edit: by bmouthboyo
You could always determine TDC the old way with a piece of dowel, let us know if you've not done it and I'll try to explain.
If I lined everything up to TDC ( cam sprocket, crank sprocket, dizzy) could I tippex a mark to the flywheel and use that?
However a GTI 1.8 is prob more fuel efficient than any of the standard T25 petrols.
Set up for and running 97/98 octane will give more power and mpg than when setup for 95 so cancelling out the few pence per litre savings of 95.
My 1.8 GTI has an arrow embossed in the cambelt plastic cover and a notch in the crank pulley, prob not as 100% accurate as the flywheel marking but a good starting point
