Series 1 gli (EG) unseized but locking up
(In Topic #207817)
Easier to clean the bores if it was rusted too.
Regards Volkswarren
Regards Volkswarren
Best bet is pull the engine out and remove the head to have a good look inside, for the price of a gasket kit and head bolts it's worth knowing the condition inside the bores and worth checking over the head and fitting new valve stem seals and checking the valve stem guides.
I'd pull it and rebuild it end of. if the bores that badly rusted it can't be good inside.
My current engine was left outside on a pallet under some tarpalling for 4 years with out the injectors fitted and it was fine inside but I did check inside just to be sure, perhaps the fact that my brother poured some oil into the bores before layed it up helped?
Didn't know vw made a non interference engine.
I will check Autodata though to be sure cause Ive not looked it up for many years.
Regards Volkswarren
Regards Volkswarren
Regards Volkswarren
I did say I've read it somewhere.
Regards Volkswarren
the 1.6 GTI has a totally flat head so I guess thats probably why
So assuming if mine is an inteference engine, can I check for a stuck open valve before stripping further? Would the bucket tappets show this in anyway? And if/when I remove the engine can I leave both manifolds in place until the unit is out complete then strip down for ease/access?rubjonny said
the later 1.6/1.8 8v are non interference for sure anyway.
Yes you can leave both manifolds on as long as its not a 4 branch.
Sent from my iPad using Tapatalk
Regards Volkswarren
Okay cool cheers it's all original, I'm thinking bonnet off, driveshafts off, radiator out and disconnect everything and lift out engine & box together, then buy a stand like this so I can be neat and meticulousvolkswarren said
You might see it, don't really know.
