Mechanical or Hydraulic Tappets ?
(In Topic #216081)
Is it safe to assume that it has Hydraulic tappets with this head as it has a 2nd oil return hole ?
Is there any other way to tell without removing the rocker cover ?
Thanks,
Bigmoose
If you have 5 caps on the cam shaft then they are mechanical, if only 4 then then it's hydraulic tappets.
Picture about 1/2 way down this thread.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-injection_2%2Ftappety-top-end#post_1539314
wilko13 said
The code at the top of the head above plug number 1 will tell you
The code is 026 103 373 F. I think this is a mechanical head, right ?
Hydraulic lifters is AA
So yours is solid lifters
