leaking heater matrix
(In Topic #150696)
Whilst removing the old carpet from my cabby gti I found a damp patch right under the heater matrix. Noticed a drip coming from the matrix casing as well and its definately coolant.
I've had a look at how to get in to the matrix casing so I can see where the leak originates from but not having much luck. Have removed the small metal clip on the bottom that holds the 2 parts of the casing together but something else is holding it together and I can't see what.
A guide of what I should be looking for would be appreciated.
Thanks for the advice.
Euan
Phil
I would like soms photos to guide me though, if you still have them?
no need to remove anything at all on a cabrio its right there. small box shaped cover to unclip then theres your matrix. as the OP found the hardest part is getting the 2 rubber pipes off the matrix as clearance is tight and they can be well stuck
2001 Zafira 1.8
2001 Zafira 1.8
I'll report back with the progress
rubjonny said
just look in the passenger footwell, it'll become obvious.
Hi John - Don't suppose you have a picture of the clips I need to undo at all do you?
I've noticed the coolant leaking onto my carpets and need to sort before I put the new ones In that are sat in my lounge! I can see the two pipes coming from bulk head, and a rectangle shaped plastic case covering these? How does that 'pop off' ??
1990 - Cabriolet GTI 1.8 (DX)
A bit of old credit card cut to shape then super glued on the back of both bits to hold it worked for me as you will never see the back.
I managed to pop the cover off this evening, so I assume all I need do now is;
a) Drain coolant system
b) Remove hose clips in picture
c) Pull heater matrix out (?)
d) Replace with new & re-attach hoses
My unit looks in pretty bad shape to be fair, not surprising it's leaked !!
jack the car up as high as you can from driver side rear to try an encourage some to come out of the matrix, but due to the design and the way it comes out you'll want a bucket under it!
if you have a couple suitable size bungs to hand you can block off the matrix outlets as you pull the pipes off, that'll minimise coolant loss. or since its already been leaking, I guess you wont care too much about a bit more
rubjonny said
no need to drain the full system, just disconnect the 2 coolant hoses to matrix in the engine bay and angle them down to drop as much coolant as you can.
Cheers as always mate - going to give this a whirl tomorrow! Wish me luck
I could not for love nor money get the coolant hose to come away from the pipe in the engine bay. Granted access is tight, but I'd need the worlds strongest man to get these out!
Any ideas at all?
