Is it dead? Please help!
(In Topic #224002)
I'm sorting out my DX GTI engine and took the rocker cover off tonight and discovered a small amount of mayonnaise. The bolts are slightly rusty and so is the camshaft and it's not looking good. Can someone give me some help? What should I do? Is the engine dead? Don't know how water could have got in. It has been sitting for 3 years or so, so I guess could have happened then. Thanks guys.
On the drive
Myvalver 89 GTi Grey mk2 16v
Kenneth Cartwright said
as above undo the bolts and lift out, whilst doing that may as well lift tappets out and give them a rub..
If it has been sat for a while it might not be too easy to get the tappets out. I couldn't get a decent hold on mine so resorted to a strong magnet (once I'd taken the tappet shim off). Might be an obvious statement - but don't mix them up, they must go back in the same place they came out of!
What I have found over the years is to use plastic baggies that I label and place the parts into them one for each Valve as in #1intake, #1exhaust… . In the old days I used Paper Sacks. Chock it up to lesson learned.
