Interchangable engine codes
(In Topic #203117)
Recently bought a new engine (DX) and have found it has a crack on the head, currently in 2 minds whether to take it to be possibly repaired or just buy a new head.
Want to know what codes my head is a straight swap with, my code of 026 103 373 AA With 59 vertically after.
I've been offered a head with the code 026 103 373 F with no vertical number, the WWO is also stamped in a different place.
Is the only possible difference in DX heads if they're hydraulic lift or solid? Pretty sure they're both hydraulic so it should be a straight swap?
Should an 83 DX originally be solid or hydraulic?
digifant heads will also fit but you need to find the right age kjet head to swap the injector inserts over so not much help if yours wont fit
Cheers again
Member 125 - 2005
Rubjonny - that's great thanks again, you seem to be answering my problems every day!
Member 125 - 2005
I will double check this week,
I think I picked up my mk1 from Honington about 5 years ago
Honiton or Honington? Think Honington is a long way from me!
