G60 engine starting problems
(In Topic #202814)
Member 125 - 2005
otherwise it just seems to be running rich, maybe check the temp sensor, resistance curve is in my digi guide plus a coupel other bits apply:
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14915
make sure the ecu vac line is 1 meter long and intact, and check the ignition timing, idle & co as per the pg….pdf documents in my signature
Member 125 - 2005
Glad you sorted it
