Fuel hose spec for KR on carbs
(In Topic #212962)
Hi all, hoping someone can help with details of the fuel hose I need (my Golf is in storage and I can't get to it easily to measure up)-
What length of fuel hose is needed for twin carbs on a KR in a MK1? And what internal/external diameter?
I know that mine had the reassuring addition of electrical tape around the hose at the first carb and I'd like to upgrade everything to a proper, secure, fire safe set up.
Many thanks for any advice and dimensions you can share!
It's all just dreaming while I'm on holiday away from the car but I'm finding it's also a good time to consider all that needs doing and hit this kind of research. So far I think the hoses are 8mm internal which is AN-6. But I'll have to get back to check if I have a filter king and the condition of the pumps and filter/s.
http://www.screwfix.com/p/wednesbury-wednesbury-microbore-copper-pipe-coil-8mm-x-10m/61031
gti's have 8mm external dia pipes from pump to filter, carbed cars have smaller dia pipe probably more like 6mm external could use brake pipe
