finding it hard to find replacement split pipe
(In Topic #209470)
http://www.ebay.co.uk/itm/VW-GOLF-JETTA-MK1-MK2-CABRIO-SCIROCCO-MK2-WATER-COOLANT-PUMP-HOSE-PIPE-/391494193221?hash=item5b26df5045:g:oaMAAOSwNsdXSFap
Ask him to measure it?
Briano1234 said
That looks to be the connect hose from the water pimp to the heater hose hard line.
yep that's the one
Raul said
This? 027121063C
thanks have asked for measurements. Looks can be deceiving with this one, having a real issue finding the right length!
They do still keep some stock of hoses, I bought a new hose from the water pump to the metal pipe a couple of years ago no problem from vw.
rubjonny said
it would help to know the exact engine code and age of the car you need it for
It's a KR engine code, the car is 1989 cabrio, but engine is 1992 16V
Have a look here for a part number then it will be alot easier to find or try calling VW.
http://www.oemepc.com/
rubjonny said
right then, the correct part number is 068121063M
thanks John, but this part has already been sought and ordered, and it's too short
post up pictures of the engine, especially of the metal pipe you have
Also if the Pipe is spaced out on the hard mount that could be up to 1/4 of an inch difference.
