Advice needed on timing on dx 1.8 k jet golf gti
(In Topic #208795)
Sent from my D5803 using Tapatalk
Want to find out a little more information on using my timing light as a lot of my manuals say conflicting stuff on degrees and the vacuum pipe on or off
I have a 1992 golf cabriolet 1.8 gti bosch kjet manual transmission. With I think a transistorised distributor.
I have found the tdc mark and 6 degrees btdc
At the moment I have warmed up engine removed and plugged the vacuum pipe at tick over 950 rpm and lined up the 6 degrees timing mark.
Could some of you golf experts advice me if the vacuum pipe should be on / off
And what revs?
As too high mechanical advance would start happening
Reason you see both is for carb engines the dizzy vac line is left on, engine timed to 18deg BTDC
Re:
rubjonny said
vacuum pipe off and plugged, 6 degrees BTDC for kjet engines
Thanks for that what engine revs would you recommend
Re:
rubjonny said
just at idle for both, 950rpm will be fine. you can usually add a bit extra advance if you're runnign it on decent fuel
Many thanks for the advice
I believe that normal unleaded needs the timing retarded by 6 degrees.
