1991 H REG MK1 GOLF GTI CABRIOLET WONT START WHEN IT GETS WARM
(In Topic #218237)
IVE RECENTLY BOUGHT A 1991 MK1 GOLF CABRIOLET 1.8GTI ,THE CAR STARTS RUNS VERY SMOOTH COMPARED TO SOME IVE HAD BUT SOON AS IT WARM OR HOT IT WILL NOT RESTART ,UNLESS YOU PULL THE BLUE CLIP OF THE 5TH INJECTOR OR WAIT TILL ITS GONE COLD
If K-jet leave the 5th injector unpluged… I ran for about 3 years with no 5th injector as I had leaking injectors but I had a problem with lumpy running when cold as to much petrol.
When the engine is hot the 5th injector should not fire, it's controlled by the thermo switch in the flange on the front of head, there is guide in the Haynes manual on testing the switch and 5th injector. Again all k-jet info as I've not "played" much with digifant.
P.S… THERES NO NEED TO SHOUT.
Life Member
Get the fuel pump checked to make sure it's holding pressure and check the warm up regulator. Get the whole system pressure checked professionally.
