Removing Rocker cover studs ???????
(In Topic #136138)
Thanks in advance
G60
Pete
Twitter Manager
the part no. for the gasket kit is 026198025c and its about £16, Im picking it up tomorrow from the dealers.
Will let you know how i get on !!
G60
Oh well best get back to it !!!!!
G60
Website Manager
Also had a look at the filter in the tank and glad i did as it was a little blocked, so cleaned out with paper clip, filler neck is stainless so thats ok, its prob from old filler neck, also got out a few bit of rust with my trusty telescopic magnet !
G60
No more leaking rocker cover as well , so can deffinately recommend the rubber gasket modification, well worth it !!!!
G60
I got this rocker cover kit too and replaced all the studs the tread on the new studs seems to stop pretty high up. My cover has gone off to get powder coated so haven't put it on yet I'm just hoping it seals like you say.
When you get the rocker cover back, if it's been blasted before power coated make sure the gauze is really clean of any stuff they used to blast it, Give it a very good wash out. I've seen and heard of engines being worn by the grit/sand left in the gauze getting back inside the engine and scoring the boars.
Picture of my studs with the rubber gasket. (no gasket fitted, I'm just showing the cam timing mark.)
With my rocker cover I rubbed it down and painted it with a rattle can.
After rub down.
Painted. I did block off the breather hole while painting, picture taken when it was dry.
Yeah got it back and looks great and fits perfect but thanks for the tip about washing out the gauze he didn't got mad up around the gauze area blasting but still I think I should take off again and try give it a bit of a wash what would you recommend washing with ?
