Pierburg carb 1.8 running fault
(In Topic #73375)
I'VE CHANGED THE PLUGS, LEADS, CAP, COIL, IGNITION MODULE AND FITTED A SECOUND HAND CARB (EBAY) BUT STILL THE SAME FAULT. I DID HAVE TO SWAP SOME ANCILLERIES OVER ON THE CARB,EG A VACUUM POT WITH TWO PIPES AND TWO WIRES ON THE RIGHT HAND REAR OF THE CARB, AND A WATER 'T' WITH A PLUNGER IN THE MIDDLE WHICH FITS ON THE FRONT OF THE CARB AND IS CONNECTED VIA THE HEATER HOSES TO THE CHOKE WAXSTAT UNIT. ALSO A TEMP? SENSOR THAT BOLTS ON TO A BLIND HOLE ON THE FRONT OF THE CARB WITH A WIRE CONNECTED TO A SMALL BLACK DEVICE? WHAT ARE ALL OF THESE THINGS FOR AND COULD THEY BE MY PROBLEM.
#HELP I'VE HAD TO KNICK THE WIFES CITREON .
On the carb front - absolute nightmare - either switch it for a fixed choke carb such as a Weber replacement unit or hand it over to a professional to setup - it might cost a little more but it'll save you hours if not days and weeks of mucking about…
