No idle at all
(In Topic #207009)
Pierburg 2E2
I noticed a problem lately with the drivability of my '90 cabby with a Pierburg 2E2
On LPG when I slowed down too fast it would cut out - I got around that by slowing down / shifting down
When I went to the petrol station to fuel up I switched to petrol it died on me - no idle at all
To finally solve the problem I installed a NOS Pierburg 2E2 carb and everything around it
The Pierburg has all settings sealed with yellow paint
The manifold had a new gasket - coolant O-ring - new flange with a light coat of sealant some 500km's earlier
New one-way vacuum valve as well
The Idle control relay and TTV get 12V - I made sure with a spare set of plugs straight from the battery to bypass the fuse box
The manifold heater and electric choke get 12V as well - those coolant temperature switches work too - fuse 17 and 18 are ok as well obviously
New bended choke to wax thermostat hose too
Note that the carb came with all brand new pieces - like the TTV - Idle relay - Pull down unit - Wax thermostat - Choke etc.
The carb is earthed as it should be
The problem however stays the same - NO IDLE at all !
NO IDLE with LPG either since I fitted the new carb
It idles just when started up from cold - as soon as there chokes open up it dies - can't get it up to idle again since the choke is a bit open
When I keep the choke almost closed I can keep it idling
Any idea where I should be looking at ?
BerT3
and click the link in my signature look for the haynes 2e2 carb manual pdf document
Perhaps the lever that contacts the 3/4 unit needs to be adjusted, or the 3/4 unit idle adjuster on the back
The manifold to the head is leaking
When covering the car and spraying brake cleaner in the region of the manifold studs the RPM goes way up
Pity since I just had a new head installed after a head gasket failure
Parts are ordered and will be installed soon
BerT3
2 bolts were shaken loose - retightened them
Still the same problem
Sprayed brake clearer around the manifold - no raise in RPM now
I suspect the vacuum non return valve to the brake booster now
I can remember I could suck it both ways
Could an air leak or non-return failure has that much of an effect on the idle - no idle at all in the second stage when the coolant opens the choke even more
It would explain the lower than idle rpms when slowing down / braking since it last ran
Any input ?
BerT3
if the servo was leaking that would cause it though, easy test take the servo line off and block the engine side. if that sorts the problem then replace the servo
