Mk1 golf 1.6 getting excessively hot
(In Topic #193942)
Where do I start? Gutted!
Any help appreciated
Lee H '77 GLS, 5 door, bronze // Trek X-Caliber 5
I'll have a good poke around in the morning. I done a coolant flush a few weeks ago so it may have some locks.
http://www.vwgolfmk2.co.uk/forum/viewtopic.php?f=37&t=14913
Swings and roundabouts, I'm in agony, but I'm online shopping for the Mk1.
Anyway….
I followed your guide and I'm 99% there's no air locks in the system, but stationary the temperature got up to around 80/85% and the fan didn't kick in? Which is odd, as I've definitely heard it running in previous days. I've not let the car get to the point where it starts to act erratically and over heat, as I've been down that route before, but it doesn't seem like the gauge is reading very accurately? For example I'll be doing 50mpg and the gauge will stick at 80% but when I slow for a roundabout it drops down to around 30%? Which makes me think its some kind of temperature sensor, or at least a series 1 equivalent of one? Also, when it gets hot, I slam the heaters on and after a little while its dragging through luke warm air at best, where as if it was getting hot, the heating would be pulling through properly hot air.
Another thing of note, is its getting through oil, but this maybe due to the rocker cover leaking.
On the bright side…. I've bought some postie lights, in the typical fashion of ignoring the problem.
the sensor is the small black one in the front or side flange with a red/yellow wire, start by checkign the spade on this and buff up the contacts
I'll post back with my findings, where it the thermostat on this anyway?
I think it does have the thermostat in place as when I ran it from cold and bought the car up to temperature the bottom radiator hose stayed pretty cold until it got up to 3/4 and then it released became hot.
with the cool heaters maybe theres something up with the matrix or the heater valve. to start with set the heater to hot then pop the bonnet and physically check the valve is fully open, if it can opened a bit more by hand a bit more try popping the cable retaining clip off, moving the valve and heater knob to 'hot' then refitting the clip. if the clip is missing, well thats probably the issue
also have a feel of the valve operation, if it feels really light and moves without any real resistance perhaps the lever and flap inside have parted company.
to test your rad fan unplug the 2 wires from the thermoswitch in the rad and jump them together with wire, if the fan runs you know all the electrical side is ok but the thermoswitch might be shot. next time the gauge gets to 3/4 have a feel of the rad to make sure its getting hot all over, especially the area the themoswitch is sat in.
if the fan doesn't run buff up all the electrical contacts and check the fuse. also jump the fan with 12v straight off the battery to check that it actually works!
