mk1 20vt, slow but getting there
(In Topic #97608)
Member 125 - 2005
Member 125 - 2005
loving the shiny bits :wink:
Member 125 - 2005
keep on keeping on
Member 125 - 2005
Nice one mate.What engine code lump is it by the way?I want to do one of these later in the year once i`v moved but not sure which donor engine would be the best?mk1jim said
yep shell is solid, front panel has been chopped a bit, car used to run a g60 with nos , but all is good
keep on keeping on
Member 125 - 2005
Member 125 - 2005
mk1jim said
i have an emerald ecu and qpeng wiring loom. benscab i know you have good results with megasquirt, do you have any experiance with this set up. i'm afraid that part may be more than i can do and will be asking for some help.
i think i have a mk1 20vt emerald map here
which inturn would have all the setting you need whats with the qpeng loom?? emerald should come with a blank loom which you solder your plugs to :dontknow:
Member 125 - 2005
least derby is only 3 hours down the road
well with the loom id use the standard 20vt harness and strip it leaving just the bits you need then pigtail it onto an emerald loom
not overly clued up on emerald tbh sell the ecu buy a megasquirt and ill come up and get it running in a day
Member 125 - 2005
i have base maps for megasquirt the only thing you wouldnt be able to do is run cop (coil on plug)
i was having this converation earlier with jamie its cheaper and easier to fit megasquirt due to the fact if you want emerald mapping how much is it going to cost? ?300 minimum id guess
where as megasquirt is pretty easy to map on a user basis if you read the papers ans you would learn alot more about how it works :wink:
Member 125 - 2005
megasquirt is cheap and cheerful and can be mapped by yourself oncw you understand what is what
so far i think theres about 8 people using megasquirt on 20vs 3 on this forum alone
nick82 is up and running
jamiegolf is up and running
ive been up and running for 2 years with no problems
theres loads of people using emerald out there you may find someone that can map it for beer tokens ask around on the forums the guy that builds the megasquirt may be able to map emerald :wink:
Member 125 - 2005
