Is steering too heavy?
(In Topic #204005)
anyway.. He said it could be an incorrect steering rack, I had the rack replaced about four or five years ago
its lowered and was replaced with new arms, top mounts etc
tyres are correctly inflated
I'm confused, does anyone else experience the same?
i would jack the front up and check all the ball joints and top mounts, and make sure the spacer is in them
Even with wide tyres it should not be heavy when you are moving so maybe have camber checked then tracking done if ball joints and top mounts are ok
Had the tracking laser aligned and checked with camber etc, all sits very true
It's been consistent as far as I am concerned, never felt it get any worse, so not sure what to do, I think the only way I am going to check us to drive another Rivage and compare
I've never had a problem with it but the chap was quite insistent. But he drives with power steering!
If the tacking, camber and tyre pressures are ok and you are happy driving it don't worry about what people say who are used to power steering with no real feel of the road are used to.
But.. When coming from my new Leon in eco mode with silly light steering, I get into the Golf and nearly stack it at the first corner thinking I can just throw the steering wheel around, you still have to work it.
I'm guessing your mechanic won't be used to cars without power steering any more.
If you're ever the Sheffield way, you're more than welcome to come compare to my Rivage to see if it's different or not.
1992 MK1 Golf GTi Rivage - Classic Blue Metallic - Long term project
1991 MK1 Golf GTi Rivage - Classic Green Pearl - Sold
