Air in brake system
(In Topic #187216)
Air in brake system
Good evening all
Another question please I have changed all the brake lines on the cabrio golf but after putting 2 lots of new brake fluid through the system still have lots of air and no pedal! I have got a sealey vacuum auto brake bleeder but do I need to bleed the system with help pumping the pedal? I have bled the system as per the Haynes manual.
Cheers Matt cf_emoticons__BangHead:
You should just be able to rope the reservoir up and then bleed each wheel individually. You will require someone to pump the pedal until no air comes out of each bleed nipple.
