Twin 40's fuel setup
(In Topic #193987)
Currently my engine has the carb fuel lines which are 6mm and also it has a single lift pump in the tank supplying my carb. When I move to twin 40's I was planning on running an additional facet pump to up the pressure.
But which facet should I go for?
Do I need to increase the fuel line diameter to 8mm as used on the big block engines?
Will I need a regulator up by the 40's in the bay? And will this regulator use the return line back to the tank?
And for the wiring, can I just run an additional wire from my lift pump down to the facet pump or will I need to run a thicker wire from the fusebox due to more current being drawn?
Cheers,
Matt
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
Which pump will be best, I was going to go for the small square one but I've seen people use the bigger cylindrical one for 40's?
Yeah I'll run a new wire just to play it safe then
Any idea on the importance of using 8mm fuel pipe?
Ive always used facet red tops myself and run one now with my 45's buddy
Thanks again mate
