mk1 cabby engine conversion
(In Topic #182925)
need more mpg!
best bet is golf mk4, audi a3, seat ibiza or whatever the equivalent skoda is
(DX 1.8 GTi engine)
There must be something wrong or driving to hard in stop/start traffic to get such a low mpg?
What engine is in the car?
It just sounds like it's running way to rich, check the timing marks on the cam shaft and then the timing with the engine running, make sure the air filter if paper type is no more than 12 months old then get the carb set up properly, with the webber it only takes a tiny turn of the screw to adjust the mixture but you really need it set up on exhaust emissions tester.
My Scirocco runs a webber carb but its just the 1.6 and I was driving it last week to work, 50 mile round trip and not really drive carfully (great twisty roads in Somerset) and still managed 37 mpg.
the 2.0 16v beats it hands down mind, but its more hassle to install in a mk1 due to needing a custom manifold. 20v is even more work but still doable lots of info out there.
with all of the above I would choose OEM managment as its fit and forget, wiring conversion isnt hard for any of them really lots of help to be found. you could always book it with me but you'll have to wait a while, otherwise I can help guide you thru it
You've already got my vote for MOTY 2014!
…just when you think it's all over!
I may take him up, I've always fancied those Porsche embossed calipers! (and i've just fitted tarox pads & discs!!!)
