1.8t conversion nightmare
(In Topic #201779)
wiring
The guy never labelled anything when it was removed, but I have most of it sorted apart from 4 wires ( I think).
The easiest way I can think of solving this is to list what I have connected first.
Coil packs, injectors, N75 valve, crank sensor (grey plug), throttle position, air temp (manifold), coolant temp, map sensor and lambda.
Is this all I need to get it up and running?
The only connectors that I don't have plugs on the loom for are the 3 pin socket which is at cam belt end of the cylinder head, the brown and black sockets at either side of the crank sensor on the engine block and the single terminal on the oil filter housing.
I would really appreciate any help. I'm pretty stuck.
Many thanks.
Worth investigating but dont quote me on it as im not 100%!!
Hope this helps
Adam
