drive shaft help
(In Topic #145997)
drive shaft help
hi all my 1989 mk1 golf gti clipper has recently started to knock from the drive shaft i want to change them but iv seen there are 2 types 90mm and 100mm can anybody tell me witch i need cheers sam
the original and still the best !
Can't see a driveshaft knocking unless it's bent, do you mean worn cv ? To check which type you have fitted remove the shaft and measure across the flat of the gearbox flange
yh its the inner cv i was told i needed the a new cup but was also told there a ball ache to do so i was gonna get the job lot
I need to change all my joints and boots, where's the best place to get these? Are OEM new parts still available?
