Jessie the tdi mk1 jetta (haldex conversion begining...) 12/09/17 update!
So the syncro rear axle got a seeing too with the grinder tonight, all old bracketry cut away and dressed back, tried the haldex in to try for size, and started mocking up the bracket kit for it, looks to be a snug fit!!
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Ok so got some more work done on the rear beam today, all welded up haldex fitted properly without the jig, just need to get it blasted now and ready for Powdercoating, collected my gearbox yesterday from martin Emment of gas and gears in Bridgend, it's been fully rebuild with new bearings and seals, preloads adjusted and arp crownwheel bolts, vagabonds rear mount fitted along with a pinion brace too, got to strengthening the clutch fork today too, just incase……
So next job on the list is to collect my rear arms tomorrow to mock up the rear disk setup and then they can be coated too…….
That's a bit of a beast now!
So rear arms are back, blasted and ready to modify for the caliper carriers, loosely fitted the arms to the subframe tonight, MY GOD it's wide! Looks loads wider than the mk1 beam!!!! Time will tell when I remove the original this weekend! Trial fitted the axle mounts with new bushes too, all looks good there, just need Timorese some correct pitch bolts as the temp Ines I have are not what I want,
Car stripdown begins tomorrow night hopefully, engine and box coming out…… stay tuned……
Fully restored and driven daily! I love my 1980 Rabbit Diesel!!
Today was a busy day, engine and gearbox out, all suspension removed, fuel tank removed, jig mounts built, car mounted to the jig and rolled over, now to asses the car, few little bits I need to sort, axle mount drivers side needs a repair as one of the studs snapped off, and sill lower lip has been folded over due to being jacked up on, so nows the time to get that sorted too,
Tomorrow's jobs are
Remove spare wheel well and rear crossmember
Clean off sealer and trial mount the axle
Got to making up the rear axle mounts tonight, got one side made up and tack welded into the car, took a good three hours to get that right! But kept all the cardboard templates so the other side should be much quicker!
So tomorrow nights plan is to get the passenger side mount finished off and then set about fabricating thebdruvers mount, more to come…..
I would love to have a haldex on mine.
DANBOY.
Mk1 Golf cabrio "Golf+ absolutely cabulous"
fresh 20vt rebuild well underway https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-old-white-cabby#post_1402754
Last edit: by jamiegolf
