G60 Conversion
RichG said
Can anyone confirm whether I need 76mm or 94mm lug mounts on the golf? I have gti calipers at present.
As soon as I know I will order up
Anyway I have treated my self to some KW V1 inox coilovers
And a new steering wheel From this :-
To this:-
Last edit: by Rich.
smudger said
Can't go wrong with KW's mate IMO. Lovely bits of kit. Good luck with the conversion. what sort of timescale have you got for it??
Ha that was weird, the page was still submitting when I got your message on my phone lol.
The engine will be dressed over the summer with Installation starting when I take the car off the road for the winter. Should get it done quite quickly If I start to get parts together now
G60 will be nice too, good call
Stage 4 baby
Last edit: by Rich.
RichG said
Stage 4 baby
Not so cool with the hand though - ouch!
Can you see whats missing
Just needs a good clean up
Last edit: by Rich.
smudger said
A leg off the hoist?
Ha it was pretty tricky removing the engine with only one leg on the hoist
Last edit: by Rich.
Last edit: by Rich.
Complete hydraulic clutch kit
KW Coilovers V1
New 9 Inch servo and 22mm Master cylinder
Restored engine mounts (Front and Rear)
Just caddys 02J engine mounts and G60 mount
From Bartek:
1 x G60 Sprinter intercooler KIT (2160sprinter03)
1 x G60 Gasket for outlet-pipe BAR-TEK® (2160086)
1 x G60 Outlet pipe for big intercooler BAR-TEK® (2160085)
1 x G60 Aluminium piping ONLY Bypass pipes BAR-TEK colorblack (216083)
1 x Short Oilfilter (2100011)
1 x G-Lader Oilhoses-Kit complete G-LaderG60 (1160004)
1 x Oil dipstick holder (2160089)
1 x G60 Waterpump SKF (2160046)
1 x G60 timing belt with tensiator (2160049)
1 x Oilcooler-Kit G60 (2260006)
1 x G60 Wateroutlet front cylinderhead (2160097)
1 x G60 Wateroutlet side cylinderhead (2160197)
1 x Sealing compound Dirko HT (2100026)
1 x G60 G-Lader Inlet flange BAR-TEK® (2160104)
1 x G60 G-Lader Cover BAR-TEK® (1160015)
1 x VA-Bolts-Kit G60 Lader (1160001)
1 x G60 Aluminium Pully BAR-TEK® (2160187)
8 x G60 stud bolt for Cylinderhead (2160183)
1 x G60 & 16VG60 Alloy Alternator Pulley BAR-TEK® (216016120)
1 x G60 Pully 68mm (2160001)
1 x VW aluminium pully BAR-TEK (2100057)
VW Spares:
1 x 3000.384.001 Clutch Kit (3000.384.001)
1 x 4264.87D Thermostat (4264.87D)
1 x 1001211027 Thermostat Housing (1001211027)
4 x WR6DP0 Spark Plug (WR6DP0)
1 x EVL134 Rotor Arm (EVL134)
1 x VK355 Distributor Cap (VK355)
1 x VK382 Distributor Cap (VK382)
1 x ZEF561 Lead Set (ZEF561)
1 x 758.728 Valve Cover Gasket (758.728)
1 x 495.620 Sump Gasket (495.620)
1 x 07407 Sump Pan (07407)
2 x Quantum Synta 10w40 (5-Litre) (Synta5L)
1 x 03272 Sump Plug (03272)
1 x 07215 Sump Plug Seal (07215)
1 x WK830/7 Fuel Filter (WK830/7)
1 x 1008009050 Temperature Sender (1008009050)
1 x 18666 Temp Sender (18666)
Only Charged Dubs :
BBM Alloy Fuel Rail
BBM Fuel Rail Fitting Kit, 8v Digifant, 16v
BBM Fuel Rail FPR Adapter
Bolt Kit for G60 Flywheel and Clutch Kit
Red Top Bosch 315cc Injectors
SNS Chip
G60 Supercharger Rebuild Service
I want the engine to look like new when fitted.
RubJohny will sort me out with my loom conversion. I think I have most bits but need to sort out a manifold and exhaust system, radiator maybe and a few fuel components (lines etc.)
Last edit: by Rich.
My fuel tank got picked up for its restoration yesterday.
Also received my rebuilt supercharger from Matt at Only Charged Dubs as well as my bbm alloy fuel rail, red top injectors and sns chip. Excellent customer service, communication was brilliant.
He noticed my Jabbasport stage 4 charger wasn't ported out on the intermediate shaft and sorted that for me
Pics to follow!
just wanted to say i want your garage SO much space haa
