1990 Cabriolet Conversion?
(In Topic #202299)
Maybe i should stick to Alfa Romeo.
I've personally helped out alot of people on other forums as best as i can and i'm happy to help and share what i know, it doesn't instill much confidence when this is my first post. so thankyou abfmk1, you are a real local hero arent you. No smiley face either!
I've personally helped out alot of people on other forums as best as i can and i'm happy to help and share what i know, it doesn't instill much confidence when this is my first post. so thankyou abfmk1, you are a real local hero aren't you. No smiley face either!
Id take a look at the projects section and use the google search box on the upper left hand side that will pull up tons of stuff.
Engine conversions are a personal thing I think as there are so many variables depending on budget, skill set, and space. if you've got a big garage to work in and can do the work brilliant. If your'e paying someone else that's a different matter. Only limit there is your imagination and pocket.
One of the easiest and quickest I understand is the ABF conversion from a MK3 GTI. Doesn't need much adding.
Will give a power increase but I'm not sure how far you want to go. So I'd look at others projects to get an idea of what's involved, the ups and downs.
Maybe start your own build thread too. Be interesting to see what you opt for eventually.
I will check that out and go from there. I dont want to do anything overly complicated to it but something pokey would be nice. I will do a build thread too
Engine Conversions - The Mk1 Golf Owners Club
What's wrong with the engine in the car?
Is it a carb or fuel injection as that will make a differance on bits you will need for a conversion.
Is it a job you are going to do or sending it away?
There is a lot of people on here that will and can help you but it does sometimes take time for a reply and as the post is really in the wrong section as most of the posts are about what's happening to your car and not questions, if others are like me and only really look at that chat part of the forum if I have time on my hands as I'm normally reading/reply in the technician section of the forum.
The engine in the car is a 1.8 8v and it is a runner but its not ticking over. Maybe a blocked jet but its a pierburg carb thats on it.
I did look into the weber route but as its not a crossflow head there is not much point to twin webers. Also from what i understand it could use the gti cam to free it up a bit more. I started thinking with what it would cost to do the mods to the existing engine maybe it would be better to throw it at a conversion instead. Either the ABF on twin webers or the AUQ. It is a project car for me so i dont have to rush anything.
I didnt realize that about the wrong section, i will see if i can get it moved.
Thanks for your help its much appreciated.
Need to start making a shopping list and when the weather is a bit milder i will start the process.
