Pair of front outer anti-roll bar brackets (Now sorted)
(In Topic #153794)
Guest user
As per the title, after the brackets that attach to the wishbones as the studs sheared off mine when I was trying to get them undone.
Last edit: by unknown
Same happened to mine. Either hard to come by or expensive to buy!! Knocked all the bolts out of mine. Bought some bolts to fit with some locking washers and threaded nuts and voila. Holding like a charm and have had no problems. Cost around £6. Can send pic if you like.
Guest user
Aye that's probably what I'll end up doing, do those stud things just hit out or have you got to drill/grind them?
Managed to knock mostbof them out. Ground one out. Just dont bend them to much or it will weaken the metal. Once they were all out. I made the hole slightltly bigger and cleaned it all up. Not sure if I used m8 or m10 bolts. Got me intrigued now so will have a look. Lol.
looks a bit tatty under there now but haven't had a problem at all.
Guest user
Nicely modded there mate! On closer inspection mine were pretty well goosed. Ended up snagging a set on fleabay.
