hi
(In Topic #141313)
hi
hi im jay and have a modified mk4 turbo golf , but on sat should be swapping this for a j plate 1,8 clipper .
im sure ill soon be asking for advice as it has the pierburg carb
j
j
1991 1.8 clipper
Welcome to the club Jay.
I also used to have a mk4 turbo that I swapped for my Rivage.
Get some pics up when you get it.
heres a link but he has swapped the weber back to the pierburg
http://www.swapz.co.uk/swapz/2012622/mint_condition_mk1_golf_cabriolet/
j
j
1991 1.8 clipper
Welcome mate, Looks nice that one pal
1992 Clipper Cabby - Love VW!
hi there, just a quick question the wheels on the rivage look excellent and i wondered what they are called? thank you
Le Castellets.
They came in 14" and 15"
Only the 15" were fitted to the Rivage.
Bargain!
Yea but they are the 14's
Still available new from VW.
plus it says on the ad webber carb fitted??
Pieburg carbs are okay if you set them up properley, there is a guide on here you show you how.
All I will say is roof, roof, roof.
Make sure the power top works ok and there are no rips tears etc, they will only get worse and it can be expensive to replace.
look for dips and hollows in the roof with it up and the frame arms poking through will suggest it needs a new top pad, check the headliner, the bit you see from inside the car, if its ripped etc, you will need to strip the roof completely to replace it.
just a few pointers.
as i said he has changed the carb , getting a new roof anyway cheapchortle said
j
1991 1.8 clipper
wow those wheels are pricey! but i do love them, thanks for the infoŽ!
