DX to ABF conversion wiring
pin 7 - starter live, splice into mk1 red/black wire to starter or run to spade on C/18
pin 8 - tci pin 6
pin 9 - ecu relay pin 86a (fit relay to holder above fusebox)
pin 23 - ecu relay pin 87 (fit relay to holder above fusebox)
pin 35 - ecu speed signal, pretty sure unused but i leave it behind fusebox just in case taped up
pin 38 - ignition live, D/2 or D/7
pin 51 - mpg signal for mk3 clocks, bin
immob plug, earth ring, green single pin plug
hefty black lead with red plug - battery live, bin (use mk1 battery cabling in lighting loom)
red lead with big yellow plug - injector live, run to spade hanging off E/14
g1/5 dash earth, only needed if mk1 has MFA. look for brown/white male spade behind fusebox plug it into that
g1/8 lambda heater, run to spade hanging off E/14
f/8 lambda earth, run to ground point
f/7 reverse, bin (use mk1 wires in lighting loom)
g2/1 mfa oil temp, only needed if mk1 has MFA. look for green/black male spade behind fusebox plug it into that
g1/11 speed sensor formk3 dash
g2/3 coolant temp, D/29
f/3 alternator, bin (use mk1 wire in lighting loom)
g2/11 oil pressure, D/1
f/6 reverse, bin (use mk1 wires in lighting loom)
g2/10 oil pressure, D/21
g1/4 coil live, D/23 (or use mk1 coil wire, cut off then splice the thinner black wire to mk1 wire if so)
g2/4 ignition live for ecu pin 38 and isv, D/2 or D/7
ecu pin 67 is for the crank sensor
ive also got a black green from pin 22
one runs down too engine plug, one runs straight to fusebox and one comes up from engine plug, so i have two at fusebox
one was on plug g1 12 the other g2 1
G1/12 is rev counter signal which comes from ECU pin 22.
ecu 67 goes straight to the crank sensor
few other questions.. is it vital for the lamba sensor? mine is shafted, well two of the wires are,
also, im using a caddy dash loom which has no rear window heater plug or the wiring for it, but i think i have a spare bit of that said loom with the plug, any idea where its ment to go on the ce1?
as for fueling, my mk1 is a poverty spec 1.1. so do i need a gti pump and tank?
if you have a spare section of loom you're best just removing the switch loom complete whilst making a note of what pins go where, then pop them into the spare sockets. have a read of the fusebox sticky and check my sig jetta89.pdf
you'll need a 67, 80 or 167 fuel pump relay, and also the wiring for the fuel pump. either fit a gti rear loom or get a spare ce1 large pin with a length of wire. fit this to plug E pin 14. run the fuel pump to that, and also put another wire to it with a male spade thats where you plug the fuel injector and lambda heater wires into
you can either fit a gti tank and pump, or fit a post-84 cabrio/scirocco or g40 shape polo lifter pump and fuel reservoir, plus a mk1 gti pump.
fuel lines i would convert the gti pump to push fitting with an m12x1.5 barbed banjo adaptor (7 or 8mm bore) then fit a digifant fuel filter somewhere and run rubber fuel injection hose. you might find mk3 golf plastic fuel lines are a good fit
bit of a shame i started with as car that had absoloutly nothing that i needed, not even the ce1 fusebox, non gti so no pump either. small block mount…..
lord help me! haha
will have to get buying bits again!
So I need the unit that goes in the tank, + an external pump!? What's the unit do that's in my tank alreqdy? . . As for the Ibiza setup, is it no good as it won't fit or no good ad it won't work? Im confused as my mk1 was modified anyway so I don't know what's original or not
the ibiza unit is completely different, you'll soon see if you try to fit it
i spoke to the previous owner today and he seems to think he fitted a scrirroco unit under the rear seat, so im guess its the setup that you suggested. il have a look tomorrow and see what is there. try and see what the part number is. what i just need the resivoir then if it is the correct pump?
this should be suitable?
9.. black/white, to pin 86a
23..black yellow to pin 87
relay terminal 30 to live
black and white pin 86 to d7?
pin85 to common earth?
also, what relay am I using for fuel pump?
