16v master cylinder +servo to mk1 cab
(In Topic #78871)
just bought a mk2 16valve master cylinder and servo for my 93 sportline was on the impresion they fit straight in but the 16v kit doesnt have space to bolt 4 brake pipe unions in only 2 is it the right kit or do i need more parts please help
i have just done this upgrade there should be 4 ports??? as they are split service brakes but if you wanted to use it just get a couple of T pieces
Mine only had 3 outlets, so I piped the rear line into the single outlet and used a T piece for the brake switch ( I only have a single rear line, not the normal two). In your case, you could use a short piece of pipe into a 4 way adapter, allowing 2 lines and a brake switch for each outlet. I'm sure some Golfs only had 2 outlets anyway.
