Issue with dash cluster
(In Topic #219931)
Having problems with my mk1 golf Gti cabrio cluster
There should be an earth strap going to the corner of the rocker cover, if this is missing or broken then a lot of these issues will occur.
Briano1234 has a fix for this which I can never find! I'm sure he'll pop along and tell us where it is again
Ian
View topic: My DIY list of things for a 90ish Cabriolet (digifant2) part 1 - The Mk1 Golf Owners Club
Check the earths 1st.
The buzzer is a sensor for low/high oil pressure and only works when the engine is over 2000 rpm not for the amount of oil in the engine so either it's a faulty sensor, instruments or you have low oil pressure/faulty or blocked oil pump.
What oil are you using?
Repairing your Flaky Water Temp Gauge | Volkswagen Owners Club Forum
Oil filter (Euro will have discounts at some point, the last discount finished Monday)
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/regular-service/car-service-parts/oil-filter/?501770059&1&df2e88f773d5c865f404b9dd795cf6fb0b433883&000231
Oil I've been using for a good few years. usally about £12 with discount at the right time.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-accessories/engine-oils-and-car-fluids/engineoils/10w40-engine-oil/?521776011&0&cc5_245
Don't forget to fit a new sump plug washer.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/engine-parts1/engine-parts/sump-pans-and-sump-plug/?333771291&1&47c8751ced189bff5450784e05f1acd1b6276fd2&000567
Genuine VW filter
https://www.vwspares.co.uk/product_info.php?products_id=1179
Oil VW would use.
AVS Car Parts
12 months or 10,000 miles for oil change.
mk1gticabs said
I've just checked the earths in the engine bay they are fine so I think the issue lies behind the cluster itself.
Checking by look isn't a good thing, either a voltage drop test, is better, but to be honest, if the ends have been replaced, replace the cables. If the cables are still OEM that is unshielded then replace them. OEM cables still on the car are over 35 years old and probably not up to shape as corrosion can build up between the strands of the cable reducing the overall capacity to carry current correctly.
Just saying as I have made a career of spurious ground faults or earthing issues on a wide variety of electrical things.
Yes we do try to help when we can..mk1gticabs said
Thank you I will be doing the oil change tomorrow this forum is so helpful really nice people on here unlike the Honda forums I've been on in the past . I've just checked the earths in the engine bay they are fine so I think the issue lies behind the cluster itself.
I do like a Honda, had a couple of Civic in the past, loved the 1992 1.6 B16a twin cam VTEC with 160ish bhp , and I deleted the CAT and bigger exhaust, bit of a wolf in sheeps clothing but you had to rev it to get the most out of it 5000rpm and off it went…. it was a 4 door Civic saloon which never went wrong, you don't see many of those about about now…
Last Honda was a more sedate family car being a 2002 1.4 SE a small child arrived in my life so needed a cheap to run car which it was and again the Civic only ever needed servicing, we did about 80,000 miles in it!
Anyway back on to the Mk1 Golf.
How to remove instrument cluster and replace illumination bulbs - The Mk1 Golf Owners Club
There is a few different designs of instrument clusters, they look similar from the front but differ behind.
Add images tab below if you have them on your computer or use the free tapatalk app on your phone and you can upload them from that app.
i have a 1988 gti kjet cabbi 1.8.
Went to give the ol girl a run out today as its the first nice day weve had this year. Had previously had the tempreture light flashing so was planning on looking into the reason for it first.
Started up no problem, but as expected the temperature gauge went straight up and the light was flashing. Next thing i noticed was a strong smell of burning plastic and smoke coming from the heater vents and from under the bonnet right up against the bulk head. had a look around and found that the heater unit has seized completely, and the switch on the dash for the rear heated window has melted at the back.
Disconnected the wiring to both, checked the fuses and neither had blown.
turned ignition on but didnt start it up and the temperature gauge goes straight up to max. Disconnected the sensors which had no effect.
re connected sensors and turned ignition on again, guage goes to half way, and stays there. Light also stops flashing, only now the lcd clock display has gone blank.
before i start pulling the dash apart, anyone with similar experience or advice?
Dave
Last edit: by DaveGTIcab
Why because there is a 10V stabilizer that the fuel and water gauge uses to keep the needles steady, if it was bad both gauges would act up.
There is also an issue with grounds to the cluster that you need to verify on the car that there is a Ground wire from the Valve cover to the Bracket that holds the coil.
You would also be better served by "Plumping" the connector on the bottom of the cluster to insure that you have better connectivity to the pins on the connector, I have also found that adding a "Frame Ground" on the wire side of the connector to the inner firewall a good thing…
As for the smoking things, I suspect that you may have fried your ground wire to the motor, it is very common to me, I have seen it on the 4 cabbies that I have owned.
On the left side of the heater box is a White or Yellow Molex connector, and on a/c equipped cars there is a 5 pin connection. The Brown wire can get toasty…Burn and then you don't have a ground to the motor so the motor stops.
I have seen it smoke while the plastic connector melts.
This could also be a issue with corrosion on the nuts that hold the thing to the cluster so it wouldn't hurt you to validate that is is working by looking at the links above to diagnose or repair a flaky water gauge.
Electricity is funny, as current will find a way around things to make a connection, and it may not be the obvious path…. Ie: I have seen Starters use Sensors, clutch, and speedo cables to seek ground when the primary Earthing points are less than stellar, and the Speedo cables I have seen melt the clusters.
So Clean your earth connections batter to frame and frame to Engine/Tranny.
The heater Switches are high Current Positive voltage. It switches the voltage in from the fuse box to different pieces of the Resistor for the motor.
The Grounds for the motor are isolated, and separate from the switch, they usually are tied to a "Star cluster" or the outer shell of the steering shaft tube.
