Tintop filler neck hose - can't get it on!
(In Topic #216633)
Am I missing something obvious here, or are the Klokkerholm filler necks known to be poor quality?
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
Any pictures?
Sent from my Smartphone
I've had them from Mark and Heritage and they were both the same. The really annoying thing is that you can buy the same thing from any 'fluid transfer' specialist. But it still won't work. You'll also find that after fighting with it for a long time it'll only go and crack around the outer edges in about 12 months time.
The only way to get them on is to heat the ends in boiling water for a long time and then use the lube of choice (I'm not going to ask why you have Vaseline in your garage ) and put it on the tank end using a wooden on rubber hammer. Then insert the filler neck end by twisting and pushing like hell on it. then secure it to the car.
I used something different tbh in the end. After having done 2 of these before and after attempting the third I gave up and used some silicone hose instead as I'd bought some for my bike carbs.
http://www.ebay.co.uk/itm/Silicone-Fuel-Oil-Hose-1-Metre-Silicone-Pipe-Tube-Petrol-Mist-Flouro-Straight/192116941259?hash=item2cbb0fe1cb:m:myk8hjW3EQAhyxKEc2-WAGw
Seems to be holding up so far.
Ian
Tempted to bite the bullet & get a stainless one along with one of the silicone hoses in your link.
I tried with my old rubber hose but I could not get it back on my filler neck, I bought a new rubber hose and fitted it to the filler neck 1st then pushed it onto the tank, I did smear a little grease over the tank outlet and filler neck.
Mine was on a cabriolet which I had to mod it fit my car so can't comment on tin top filler necks.
If you are using the filler neck you have give it a good coat of paint (don't use hammerite as it's to hard and chips off easily) stone chip paint or simular is what you want.
I hope you get it sorted.
